Discarded means Meguyveer. He's always picking something up and then you see how he uses it? I meant saw the old Shorai not a BS style that came with the bike. Correct me if I'm wrong, but there are no lith batteries for production bikes. E-bikes sure, but it's BS for all their normally aspirated bikes.
Back to a chemical reaction is to use baking soda and water to neutralize the acid. Then you can cut a BS battery open and salvage the lead [lead-acid battery] and melt the lead for fishing sinkers... as meguyveer thinks... Gee I'm hungry for a hacksaw.
Here, imagine looking inside a Shorai battery case. Forget about the charging connector in the middle. Just think of the (+) wire and (-) wires as arms and a 9v batter dangling in the middle. Sure it's stabilized so the wires don't break off as if the 9v was a pendulum. Doubt if the bottom case has the 9v sitting at the bottom with longer arms?
What it [race pack] looked like was something like this. It had the charging connector too. Plaster of paris is out, soak this fiber to make you hand from moving is that new casting ribbon call it. It was kind of this material but shrunk tight like the blue one here. That's what I held in my hand basically.
https://ae01.alicdn.com/kf/HTB1xQeZD7yWBuNjy0Fpq6yssXXak/Scooter-battery-36v-4-4ah-battery-for-scooter-10S2P-20pcs-battery-inside-with-PCB-lithium-battery.jpg
Again, I said that little battery pack out of that Shorai case is right up Rook's alley. So you know it's so light, not much is spread out like a lith cage call it. Lined up like a wet battery, but lith battery after battery filling the top to bottom inside, no.
And just to be safe, I'd run a test bulb and drain the battery before I'd take some outside friction to it; if not touch both poles in the pack, or heat the chemRe to light off like a match... ass he saws away by a pond, pool, bucket of water say... oxygen is water so read up as we mix heat and chemRe is messing with E.
That was a hand-me-down racing style lith battery that velcro pads can't find a place for. That, or goop glue and take your pick for a solid mount. Look ma, no plastic battery cage, rubber strap, steel cage plate w/bolts. The scale reads?... did you drop the empty battery case on the scale too?
Disclaimer: WATT was I thinking?!
I never opened either a BS or lith style battery case. The Shorai battery pack was what I saw that looks like it came out of a Shoria, or that was some mean looking production quality type rip the lith batteries out and wire up the charger connector? I don't think so.
Here is where I'd saw a small enough 45° cut at the corner [opposite the post side], go down the other end and cut that tiny hole off the same way. I take a look down the ends and if I see daylight? Think of this as meguyveer weight is the sacrificial Shorai battery case. If you are using the battery tray, steel band, etc.
See me chasing weight?
Clap-Clap cage on-cage off...Clap-Clap case on-case off.
* Last updated by: Hub on 6/17/2021 @ 3:40 PM *
